96 Geo Metro LSi 187000
Topic Started: Jul 19 2012, 06:30 PM (727 Views)
lithtweezie
Hi forum members. I have a 96 Metro 1.3 w/auto. It's got 187,000 on the odometer and these are the dry compression readings for cylinders 1,2,3 & 4 - 96, 94, 110 and 115. I didn't do a wet because the numbers were so low. I believe my next step is a head pull and rebuild, but I want to make sure before I get started. It starts up and will run but, when I try to accelerate it cuts off. :hmm Appreciate the advice.
thanks Eric
Once a cylinder gets below 100 PSI they quit firing and begin the missfire. I suspect burnt valves. Is the check engine light on also?
lithtweezie
The check engine light is not on - I do get an intermittent engine service needed light. Also sent you a complete picture of my rebuild so far. Thanks Eric
lithtweezie
I didn't know what a burnt valve looked like when I started this project. I DO NOW :smackface , :holycrap
lithtweezie
http://db.tt/FxoCiS0y
rydholm11211
Big sky
If it were me I would just do a complete rebuild on that thing! top and bottom!
lithtweezie
Thanks rydholm11211, I am leaning in that direction
Don't fall over. :lol
Here are a list of links to ponder....
98 Metro Rebuild
Engine Rebuild Top and Bottom
Detailed 1.0 Head Rebuild Guide
Bottom End Rebuild Guide
Rebuilding Hydraulic Lifters
Engine Torque Specs
Engine Rebuild Kit Thread
eBay performance head gaskets
Engine Rebuild Post #1 with pictures
Engine Rebuild Post #2 with pictures/URL]
How to clean a G10/G13 Oil Pump
lithtweezie
Thanks Bad Bent for the great list of resources.
