SURGING IDLE: IAC or Vacuum Leak?; Need Diagnostic Help
Topic Started: Jul 21 2012, 02:37 PM (6,397 Views)
Khaney01
Hillbilly at large
Fyi....I fiddled with the tps and it never helped. If I got it to quit surging I got some hiccups when shifting. So far IAC unplugged and tps in original spot seems to run best.
Khaney01
Hillbilly at large
Sorry for hijacking your thread. Our problem is so similiar I figured 2 heads are better than 1.
GeoZone
Khaney01
Aug 16 2012, 04:14 PM
:) No worries, it's like you're doing the work for me! So when I take the vacuum off the IAC and plug them I have no surging either, but I think there is a reason for the IAC so I want to fix it, not just bypass it. I've heard that if you don't maintain the IAC one symptom is dim headlights and other issues under electrical load.
Khaney01
Hillbilly at large
All I did was unplug the electrical connection and mine runs perfectly. All the vacumn lines are still hooked up. I'm gonna get serious about calibrating the tps tomorrow and see if I can get it running right with the plug connected. I will let you know if I succeed or fail. Lol
GeoZone
:banana :banana :banana :banana :banana :banana :banana :banana :banana :banana :banana :banana :banana :banana
YES! I got it fixed!!!
Totally surprised when I got it all back together and it worked. I replaced the PCV valve, cleaned the EGR valve, and rotorooted the intakes to the EGR. Followed this thread on the EGR http://geometroforum.com/topic/678529/1/ and pcv valve installation from this youtube vid http://www.youtube.com/watch?v=OZbq0YXthB0 which really only showed me the location, but also was good encouragement to do the job :)
But . . . I don't think that either of these things were the actual cause of the problem. Let me explain. After roto rooting the EGR ports I turned the car on to see if I could hear the sucking/puffing that Johnny said I should here. Sounded really bad like and exhaust leak but seemed to be doing the job. But the main thing was that I could hear that surging really soon and really bad. So I thought "oh well" that didn't work. But here's the thing - there was no old EGR gasket. When I put the new one on and everything back together. voilla!
It idled so low I thought it was going to stall out. But it didn't. I took it for a test drive, got it nice and hot. Purred like a kitten at every stop sign. NO SURGE, and the idle, like I said is so low I thought it was going to stall. But never did . So I guess it's good. :banana I'm pretty sure it was the missing EGR GASKET that created a vacuum leak and therefore the surge. Snowfish was right.
My wife said "you have value to me again" afterward :lol .
Edited by GeoZone, Aug 19 2012, 08:45 PM.
Khaney01
Hillbilly at large
Rock on! Glad you got it fixed. I got distracted by something shiny and went to play golf yesterday instead. Lol
