| OIL PAN 98 Metro | |
| Tweet Topic Started: Jul 24 2012, 03:33 PM (604 Views) | |
| StackChips1 | Jul 24 2012, 03:33 PM Post #1 |
Oil plug is striped looks like i might have to drop oil pan if i cant get plug out or fixed do you have to remove the exhaust is this a common problem the plug just spins |
| Deleted User | Jul 24 2012, 04:35 PM Post #2 |
You're screwed. Spectra Premium is an aftermarket brand oil pan that is available. Check eBay, and your local parts suppliers. Make sure you get the one with the hole for the crankshaft position sensor. The torque value on the oil drain plug is 26 foot pounds. That's tight enough, but not very tight. You have to disconnect the exhaust from the manifold or the head, whichever is easier and let the exhaust drop down just a little bit, maybe. I think I've actually got an oil pan off without hanging the exhaust down, but I can't remember. |
| razr769 | Jul 24 2012, 04:41 PM Post #3 |
Got boost?
I'm pretty sure I have too |
| StackChips1 | Jul 24 2012, 05:20 PM Post #4 |
Ok IM back I managed to get the old plug out with some plyers and pulling while turning the plug was striped bad installed new one no leaks good to go on that just trying to figure out the ac now the ac clutch on the compressor is loud ac not blowing COLD but cool added some freon and it might have helped a little but not much do you think the compressor is on its way out the reason its not COLD |
| razr769 | Jul 24 2012, 05:29 PM Post #5 |
Got boost?
when did you refill it? Sometimes it takes 24 hours to start blowing cold |
| StackChips1 | Jul 24 2012, 05:48 PM Post #6 |
I charged it about 30 minutes ago and took it around the block and didnt notice too much of a difference |
| Johnny Mullet | Jul 24 2012, 06:28 PM Post #7 |
The proper way ti diag a workng, but poor performing a/c system is to do a full evac and recharge adding dye to the system. When the a/c performs poorly again, check for leaks with a UV light. Noise does not necessarily effect a/c performance, but needs to be addresses first. A bad compressor will cause a/c performance issues. |
9:41 AM Jul 11
