Convertable rubber seals
Topic Started: Jul 25 2012, 01:44 PM (985 Views)
91geoconvert
Ok guys hope this is the right section but i was curious to know if anyone makes the rubber seals for the ragtop and maybe the doors?
clarkdw
No
Scroll down. There is a set here. http://teamswift.net/viewtopic.php?f=15&t=54079
t3ragtop
before that link gets you all heated up, scotty told me via pm that those seals were sold.
he sent me the plastic window standoffs that were on the ends of the stainless steel mounting strips for my red vert.
get ready for some serious sticker shock when you find those seal available. generally, they will be $100 and up. think long about the cost and the seals will disappear to someone else. :D
Huskerdaninva
t3ragtop
Jul 25 2012, 06:31 PM
Dang, I was just going to make the same inquiry about the convertible top window seals for our '93 LSi convertible. Spent the day getting her all cleaned up and noticed some of the seals are pretty rough. I'd heard those seals were tough to come by, sigh...
Anybody have any tricks or techinques to do a home refurbishment?? I'm open to ideas or suggestions...
91geoconvert
hmmm this vert thing is proving to be more of a challenge than i thought.
t3ragtop
soaking the crunchy seals in son of a gun is good for them. when they are flattened, they're hard to recover. if they are torn, you can tack them together with a good, high body adhesive. i use black. glue them up before you soak them in the son of a gun.
Huskerdaninva
t3ragtop
Jul 26 2012, 05:03 AM
Not a bad idea. My main issue is I'm missing some material on the driver's side vertical window seal along the rear of the driver's window edge. Thought about trying to bond some new material to the original seal and form it as need be, but how and what material and adhesive to use?? My first thought was the foam insulation for water heater pipes/lines. Thoughts or suggestions up to and including "go soak your head"!? :hmm
91geoconvert
well my seals are not horrible they are better than most that i have seen but they do have a small leak in a few places maybe i can get some pics up
