reset check engine light
Topic Started: Jul 28 2012, 08:57 PM (877 Views)
chadvmurray
how do you reset check engine light so it goes off? :hmm
Repair the malfunction that kicks it on.
chadvmurray
i did misfire on cly 3 new plug
Disconnect your negative battery cable for about ten seconds and reconnect it.
busteriver
Go to Auto zone and have them run a free scan, They are not allowed delete the red flag. "You" are allowed to push the delete button. They've never had a problem with me deleting the code. Of coarse if you haven't corrected the problem the light will return. Also try the battery disconnect first.
Edited by busteriver, Jul 28 2012, 09:20 PM.
If you fixed the problem it will go off on its own. Takes 5 complete warm up cycles or something like that.
