| XFI total seal GAPLESS TOP ring any good?; xfi piston compression ring gapless | |
| Tweet Topic Started: Jul 30 2012, 03:08 PM (1,095 Views) | |
| socal geo garage | Jul 30 2012, 03:08 PM Post #1 |
HI ALL I AM IN THE MIDDLE OF A REBUILD ON MY 1994 METRO XFI WORKING WITH PERFECT STANDARD BORES AND STOCK XFI PISTONS THAT MIC. OUT LIKE NEW.I AM REUSEING THESE STOCK 2 RING PISTONS AND WANTING FEEDBACK ON THE TOTAL SEAL GAPLESS TOP RINGS FOR THIS PISTON HAS ANY ONE USED SAME OR READ FEEDBACK FROM SOMEONE WHO HAS USED THEM ? HOW DID THEY SEAL UP /BREAK IN OK? ETC. THANK YOU GOT A PRICE FOR GAPLESS TOP RING SET FOR MY METRO XFI THREE TOTAL SEAL GAPLESS LESS THAN 100 DOLLARS. |
| lwgm | Jul 31 2012, 01:34 AM Post #2 |
I heard that they work really well, but I also heard that they don't last as long. Do your research. |
| Deleted User | Jul 31 2012, 02:55 AM Post #3 |
Believe it when you see it. The gapless rings are supposed to be no longer available. Best to pick them up in person at a local parts place so you can leave them on the counter if they're not the right thing. |
| metromizer | Aug 1 2012, 01:28 PM Post #4 |
Measure the ring width, know your diameter and contact Total Seal directly. If they won't talk to you, send me a PM. One of my facebook friends sold for them for 20 years, might be able to help. |
| Sparky | Aug 15 2012, 01:37 PM Post #5 |
I no longer use Total Seal because of the probability of oil consumption problems. If one builds 10 engines using Total Seal probably 5 or 6 of them will use oil and this is after consulting with Total Seal and using every one of their suggested cylinder wall preps and methods. I am, in fact, getting ready to pull the 383 out of my El Camino and freshening it up using simple moly faced Speed Pro rings and will skip the Total Seal rings across the pond. Chiles and Alberts gapless rings were good rings to use until they went out of business so at this point, I would suggest using steel/chrome rings. That's what I used on my 1.0 liter Geo and so far it's trouble free, using no oil, and has 190 psi cranking pressure. This is with about 65,000 miles on it since the rebuild. Good luck. |
| Good bye | Aug 15 2012, 11:57 PM Post #6 |
Thanks Sparky, that is good to know. |
9:35 AM Jul 11
