| Won't run; Metro won't run w/ vacuum line attached to MAP sensor | |
| Tweet Topic Started: Aug 2 2012, 08:33 PM (418 Views) | |
| nickcoop82 | Aug 2 2012, 08:33 PM Post #1 |
So here we go. I have a 1991 Metro XFi. The only way I can get it to just idle, is to pull the vacuum line for the MAP sensor. When the MAP sensor vacuum line is connected, the engine seems to flood and then dies. I can keep it running by pumping the gas, but the exhaust smells really rich. I'm sure its something very simple, but I don't know where to start. Any suggestions would be awesome.
| mwebb | Aug 2 2012, 09:56 PM Post #2 |
FOG
three pins on the MAP sensor one is supposed to be zero volts relative to the battery negative , the other end should be 5 volts relative to battery negative the center should be about 4.5 volts key on engine off and as vacuum increases on the vacuum port of the MAP sensor voltage should get closer to 1 volt test the MAP sensor circuit to see if yours is showing those voltages use T pins to test the MAP sensor while it is connected see T pins in the electrical section of this forum the 0 and 5 volt pins must be just that , within 50mv relative to battery negative |
| Memphis metro | Aug 3 2012, 05:36 AM Post #3 |
Engine ever been rebuilt? Start with right things right first. Do a engine compression test. If the compression is within specifications, tune it up with new spark plugs and wires and distributor cap and rotor. Then proceed to find after knowing these things are right why the car will not idle correctly if the idle problem still persist. Quit unplugging the map sensor, this will make it run rich. After reconnecting your map sensor connections and leaving them alone, disconnect your negative battery cable for ten seconds and reconnect it then drive the car for a while and see if the check engine light comes on. If it does, find what the codes are and post them here. Before you do any of that, do the engine compression test and the tune up. Welcome to geometroforum. |
9:40 AM Jul 11
