| Check enging light comes on and off.; Should I drive it this far to rehearsals? | |
| Tweet Topic Started: Aug 3 2012, 04:45 PM (807 Views) | |
| vintagelove67 | Aug 3 2012, 04:45 PM Post #1 |
I have a 1996 Geo Metro LSI Hatchback and the check engine appears from time to time. Recently, my oil kept leaking but that was fixed by buying a new hose. Apparently, the previous one has a hole in it. So far, my oil hasn't been leaking but the check engine light still comes on. I've had this car since about February 2011 and have been keeping up on the maintenance so far (excluding a minor wreck I had last year which knocked the front headlight off a little). So I'm basically wondering if it would be a smart thing for me to drive it to rehearsals from time and time. It's a 24-26 mile drive (36-44 minutes) and the rehearsals are only like 2-3 times a week. Will I be pushing me little metro if I do this? I just hate to keep riding with someone and giving them gas money that could be going in my car and it's really stressing me out. Thanks! |
| Old Man | Aug 3 2012, 05:51 PM Post #2 |
allmountain40 drives to work 5 days a week. about 100 mile round trip I believe |
| Memphis metro | Aug 3 2012, 06:15 PM Post #3 |
If the car runs ok, then drive it. Have someone at autozone check the codes and get a print out of them and post them here. If the car is running good to you, forget the check engine light and drive it. Its not going to hurt anything but for optimum performance repair what is kicking on the check engine light. If the car is missing and running rough, dont drive it. Runs ok, drive it and you will be ok. As for the leaking oil, keep it full and keep a regular check on the oil level and do not let it get too low. |
| Stiffchezze | Aug 3 2012, 07:05 PM Post #4 |
Sir Metrologist
on going to get the list of codes and posting them here. Use this general rule to figure out if you should drive your car with a light on: Use the color of the light RED light. STOP NOW!!!! I.E. oil pressure lightYELLOW light. Take it easy and drive with caution. Check as soon as you get a chance. I.E. Check Engine LightGREEN Light. GO!! I.E. shift lightThis is not a hard and fast rule but it should help you out! ![]() Also, Unless I'm forgetting something, We don't have any hoses under our hoods that carry engine oil..... What hose did you replace? |
| Woodie | Aug 4 2012, 05:39 AM Post #5 |
Yeah, find out what the CEL is for, easy enough to get the codes. Coming on and off over time is often P0420, just a tired catalytic converter, won't hurt a thing, just prevent you from passing your emissions test. If the CEL starts blinking, then you should get if fixed NOW. Edited by Woodie, Aug 4 2012, 05:40 AM.
| vintagelove67 | Aug 6 2012, 11:41 AM Post #6 |
Thanks for replying everyone! I'm going to go to autozone or somewhere to get the codes checked as soon as I can. To me, the car is running pretty smooth. At least, smoother than my friend's 2004 Impala. To Stiffchezze: Thanks for the rule! Oh and I meant to say that my car kept leaking coolant because I had to keep water in my car to prevent in from running hot. So it was actually a coolant hose that had a hole in in and I had that replaced. My car was actually leaking oil last year but I immediately got that fixed. To Woodie: I think it might be a tired catalytic converter. If it starts blinking, I'm going to immediately take it to the shop!
Edited by vintagelove67, Aug 6 2012, 11:53 AM.
| Memphis metro | Aug 6 2012, 11:48 AM Post #7 |
If you live near shelby farms I will scan your codes for you if you like. |
| Stiffchezze | Aug 6 2012, 12:01 PM Post #8 |
Sir Metrologist
| vintagelove67 | Aug 6 2012, 12:08 PM Post #9 |
Unfortunately, I'm in the midtown area.
I.E. shift light
9:36 AM Jul 11
