idle issue
Topic Started: Aug 5 2012, 08:11 AM (439 Views)
freegeo
I am getting a free 96 geo metro hopefully today. The car after it warms up and goes into closed loop starts to idle high. I cant remember if it stays high or it revs up and down.
Is this normally a throttle position sensor issue or can something else cause this problem?
Thanks
The TPS is simply a rheostat of sorts.
IIRC This is usually a vacuum issue as in vacuum hoses - you should replace all of them - or a gasket leak on the intake side. And if not a vacuum leak the possibly an O2 sensor problem. O2 Sensor testing and Engine Idle Surge
Hope that helps.
freegeo
I got the car today. It still has the idle issue. I have to get the battery charged to start it on it's own. The brakes are out so moving it is difficult.
Will the idle issue throw a code. I have a code reader and a scan tool to read sensor readings.
