g10 engine removal; Know where I can find instructions?1
Topic Started: Aug 5 2012, 01:00 PM (2,721 Views)
rydholm11211
Aug 5 2012, 10:34 PM
If you are not stupid it is pretty easy to remove an engine, if you are stupid, then you might want to have your girlfriend do it for you!
Where is CB's Liz when you need her? :thumb
cwatkin
Yeah, I left my intake/throttle body attached when swapping mine. I doubt I would have been able to change the engine and transmission by myself though and the clutch needed to be replaced anyway so not a big deal. I would have changed the timing belt and water pump during the swap as I don't know the history on the ones there were installed. I suspect the water pump was about done for but the timing belt looked like new.
Conor
