| CV half shaft replacement.. how to? | |
| Tweet Topic Started: Aug 5 2012, 10:48 PM (4,283 Views) | |
| wayn | Aug 5 2012, 10:48 PM Post #1 |
Really fresh fish
CV half shaft replacement.. how to? OK.. remove the axle nut and swing the suspension end away from the car. Pop the cv out of the trans. Then what? do i need a puller of some sort to get it out of the bearing or will it slide out ok? Time for the big hammer? I dont want to do the job before I have all the stuff needed to do it. |
| poorman1 | Aug 6 2012, 04:06 AM Post #2 |
What bearing? |
| Cobrajet25 | Aug 6 2012, 05:38 AM Post #3 |
1) Remove the 32mm nut from the axleshaft. 2) Jack up car, remove wheel. 3) Remove the 14mm pinch bolt for the lower ball joint, and separate the joint. 4) Drain trans, and pop inner CV joint out of trans. 5) Tap the outer end of the axleshaft with a mallet...it will slide out. Sometimes they get a little rust and stick a bit. |
| Bad Bent | Aug 7 2012, 01:14 AM Post #4 |
These links might help: CV Joint Replacement Half Shaft Replacement. |
| Shinrin | Aug 7 2012, 01:43 AM Post #5 |
Socket for the axle nut, fresh tranny fluid, big screwdriver, socket set. Fairly easy and straightforward. My axles came out with just me pulling on them. Going in was a little harder, but I got it in by hand without using a lot of force. |
| wayn | Aug 8 2012, 07:26 AM Post #6 |
Really fresh fish
Thanks for the info. Is the nut 30mm or 32mm??? |
| Scoobs | Aug 8 2012, 07:52 AM Post #7 |
30 mm I do believe |
| Bad Bent | Aug 8 2012, 06:27 PM Post #8 |
And I got mine in a 1/2" drive at Ace Hardware. Like I had a choice.
| wayn | Aug 15 2012, 11:11 AM Post #9 |
Really fresh fish
thanks everybody. Replaced the axle in 20 minutes, couldn't have been easier (I guess it helps that i had everything apart when i did my engine a year ago) I now have a car that turns left without any clicking noises or thumps. |
| Bad Bent | Aug 15 2012, 02:00 PM Post #10 |
| wayn | Aug 29 2012, 07:37 AM Post #11 |
Really fresh fish
I refilled it with sychromesh. the drivers side seal started leaking bad. So I had to pull that axle and change the seal. Is it that much thinner? Good thing Metros are easy to work on. |
| Old Man | Aug 29 2012, 08:59 AM Post #12 |
GOOGLED geometroforum CV half shaft replace And the following several threads came up: Replace half-shaft, or just the boot? - Geo Metro Forumgeometroforum.com › ... › Metro Tech › Transmission/Clutch/AxlesCached You +1'd this publicly. Undo 15 posts - 8 authors - Aug 29, 2010 So today I discovered the right front outer CV boot on my Metro is torn. Car has 120,000 now on a '98. Should I replace the half-shaft, or should ... CV half shaft replacement.. how to? - 10 posts - Aug 5, 2012 Remove Drive/ Half Shaft Procedure - 15 posts - Nov 17, 2010 replacing cv halfshafts? - 15 posts - Sep 16, 2010 CV joint replacement - 15 posts - Dec 22, 2009 More results from geometroforum.com » Edited by Old Man, Aug 29 2012, 09:01 AM.
3:34 AM Jul 11
