New Motor... It's a runer..
Topic Started: Aug 6 2012, 12:47 AM (497 Views)
datona paul
Hi All.. After cranking the new motor over w/out plugs n relay to build oil pressure... Then re-installing plugs n relay.. I hit the key and after turning over one time started right up.. :) I broke the cam in and drove it to fill the gas tank... Sweet!! I'll check the timing and other adjustments tomorrow. I had cleaned the cat/converter w/ Tide and Hot water.... Just a bit of Smoke for the first few minutes.. ;)
paul11211
Sweet you will have to swing by my house so I can check it out!
Congrats on the successfull motor change!
datona paul
Thx... No Problem Paul.. I'm upgrading the grounds tomorrow... Digging out the FSM.. intermitent miss w/ headlights flickering. Changed out the break-in oil at 120 miles.. :)
