EGR Valve Does not hold vacuum; Tech help
Topic Started: Aug 6 2012, 06:56 PM (1,052 Views)
Rang-a-Stang
Schmuck
My EGR Diaphram should hold vacuum, right? When I apply 10 psi of vacuum using my hand pump it bleeds off in about 10-15 seconds or less. That means my diaphram and ultimately the whole EGR V should be replaced right? Just want to make sure before i drop the 80 bucks for a new one.
Yes, this is becuase I failed smog and my NOx are high. I have cleaned my passages. found this while troubleshooting.
It should hold vaccum. Dont drop the 80 bucks and get a junkyarder.
crankcase
I suppose it would be worth trying a good cleaning.
JellyBeanDriver
Yes it should hold vacuum.
