| 95 metro window off track | |
| Tweet Topic Started: Aug 8 2012, 01:12 AM (1,230 Views) | |
| Gnarlic | Aug 8 2012, 01:12 AM Post #1 |
My driver's side window glass has come off the track. It had been rolling up unevenly for a while, and being kinda lazy I had put off taking off the door panel to adjust it. While tightening the bolts to keep the lift and stuff in line, I managed to get the glass off the front track, and I can't figure out how to get it back on. Is there any trick to getting the window back in line? I park my car on the street so a rapid response would be welcome!
| Memphis metro | Aug 8 2012, 06:33 AM Post #2 |
Theres a bolt that holds the track on the left side near the bottom. Remove the bolt and pull the track down. |
| Gnarlic | Aug 8 2012, 11:54 AM Post #3 |
Thanks! I somehow managed to get it back on the track without doing that, no clue how. |
| Woodie | Aug 9 2012, 04:28 AM Post #4 |
Until you get around to fixing it right (there's a thread about that) spray all the rubber seals and channels that the glass moves in with Silicon Lube, it's a clear oil in a spray can that is designed for rubber. The main bind is usually where the mirror, window frame, and door all come together.
Edited by Woodie, Aug 9 2012, 04:30 AM.
9:24 AM Jul 11
