Timin belt doesn't fit anymore...; After 3tech cam swap
Topic Started: Aug 8 2012, 12:01 PM (1,365 Views)
texan821
I am no longer a member
Last question. Can I start the car now, or do I have to put everything elseback together first?
texan821
Aug 8 2012, 08:13 PM
Thank you, sir! I can't really take any credit though...most of what I've accomplished on the Metro needs to be credited to the members of this forum.
I genuinely appreciate everyone's help today. I don't think I could have done it without y'all.
clarkdw
texan821
Aug 8 2012, 08:20 PM
Put the crankshaft pulley on. It holds the timing belt on the sprockets. The rest can wait. Just don't run it too long with the waterpump not running.
Alpine
1020cc G10 GOML
glad you got it dealt with!
Stiffchezze
Sir Metrologist
:banana
Ditto on the crankshaft pulley, or your have to start all over! :O
3220onr
I had a similar problem with my new belt and new tensioner... I ended up putting the belt half way across the teeth of both the cam and the crank gears, then is would slide behind the tensioner. Once it was behind the tensioner I gently pushed the belt completely onto both gears. Made sure everything was good to go and then started the engine to make sure. Did not run long maybe 30-45 seconds because water pump was not hooked up yet. Its a happy day when the 3 banger fires up!
DBG USN(Ret)
