Rocker shaft torque specs
Topic Started: Aug 9 2012, 04:09 PM (194 Views)
WVSpaceman
I have a repair manual, and the torque specs for the rocker shafts says 9 ft/lbs.
can that be right?
I would think it would be more than that.
Alpine
1020cc G10 GOML
what car are we talking about your 95 shouldnt have rocker shaft
on my 87 t3, the 9ft/lbs was on the screw that holds the rocker shaft in
WVSpaceman
My 95 has 2 rocker shafts.
it is the 4cyl
Alpine
1020cc G10 GOML
alrigty. that torque specs 7- 9ft/lbs is on the screws that hold the shaft in
Edited by Alpine, Aug 9 2012, 07:21 PM.
WVSpaceman
There are 4 bolts across each rocker shaft that go through the shaft.
Alpine
1020cc G10 GOML
WVSpaceman
Aug 9 2012, 07:37 PM
well then :smackface
i am not familiar with the 4cyl rocker shaft/arms
so apparently i've have been no help at all :'(
but if this make you feel better about it being a low torque,
my 87 3cyl use's screws and the same torque :D
im sure that spec is correct from the manual
Edited by Alpine, Aug 9 2012, 08:52 PM.
WVSpaceman
ill drive it a day or 2 and recheck em.
GeoPete
AAS Auto Technology past ASE Master Tech
Do not torque them to spec, unless you want the bolt to break, and the cam bearing cap to come loose and have a drop in oil pressure and spin a rod bearing. This happened to me on my newly rebuilt engine last fall. When you tighten the acorn nuts at the end of the bolt that hold down the valve cover, the torque goes way up. Now I simply put blue thread locker on them and lightly snug them down. Live and learn (after buying a new crankshaft and bearings).
WVSpaceman
im just really confused.
my car does not seem to have the things you are describing.
it does not have screws that hold the rocker shafts down, it has 4 bolts.
it doesnt have any acorn nuts on the rocker cover. it has 4 bolts that hold the cover on.
maybe i should post some pix of what im talking about.
Yes, 9 lbs/ft sounds about right. Doesn't take much.
They're all telling about their three cylinders, nothing like your G13BA.
