Up grading to OBDII???; changing a 95 OBD computer to a 96 ODBII? How hard is it?
Topic Started: Aug 9 2012, 04:45 PM (493 Views)
95 Green Flash
Hi guys I have a another great question! I got the harness out of a 96 2dr metro 1.3L that goes behind the dash so my AC conversion because I don't have the plugs in my harness. but the 96 harness has a different connector for the smog hook up under the driver's side dash. So the question is can I buy a 96 computer and run OBDII with the newer inside harness and stock under the hood harness??? the 96 has the same components on the motor as I do. Thanks for any help! :hmm
mwebb
FOG
some late 1995 cars
were really OBD2 systems sans Mode6
look on the emissions tag for OBD1 or OBD2
if your system has OBD2
you will have a rear 02 sensor
and
a crankshaft speed sensor
if your engine does not have those things , you will need to make some changes prior to switching
