| Noise like a flat spot on a shopping cart wheel | |
| Tweet Topic Started: Aug 10 2012, 02:59 PM (788 Views) | |
| ladybug94 | Aug 10 2012, 02:59 PM Post #1 |
Have a 94 Geo Metro 1.0L. Have changed the front wheel bearings both sides but car still has the weird sound of a flat spot on a shopping cart as it drives down the road. Seems louder going round curves in both directions. I have no idea if it is in the wheels or if it is in the steering area. Book says may need lubricant in ball joints or another component but says nothing about how to do the lube job. Any and all suggestions welcome please. |
| geogonfa | Aug 10 2012, 03:30 PM Post #2 |
curious questions...have you checked the tires for: out of round? or a tire belt separation? is it a clicking noise or a thumping noise? do you have any vibrations in the seat or the steering wheel? |
| ladybug94 | Aug 10 2012, 03:36 PM Post #3 |
tires are good, new, balanced 6-7 months ago. No vibrations, just a thump thump thump that goes faster the faster you drive. Car has bad cylinder and so runs rough anyway but this noise is new in the past two months. I am new at figuring out the problems on this little car but love driving it. Use to working on Ford Aerostar's. Possible ball joints/control arms??
Edited by ladybug94, Aug 10 2012, 03:49 PM.
| Nyquil-Junkie | Aug 10 2012, 04:56 PM Post #4 |
If it gets worse when you hit the brake, you have a warped rotor. If not, it sounds like you have a bad tire. Check and see if it has any bulges or odd spots on the treads. |
| ladybug94 | Aug 10 2012, 05:50 PM Post #5 |
Okay, you two have me thinking now. I will have the place that put the tires on check them out. They are fairly new but that does not always mean anything and that would be the easiest fix. Any suggestions if the tires are good? |
| Nyquil-Junkie | Aug 10 2012, 06:21 PM Post #6 |
A midget trapped in the trunk with a hammer? |
| busteriver | Aug 10 2012, 06:25 PM Post #7 |
That would be a trunk monkey. |
| ladybug94 | Aug 10 2012, 08:35 PM Post #8 |
Sorry guys, no trunk to hide in To many tools and fluids there besides the chipmunks in the engine compartment would find the trunk monkey and have a party. Will have tires checked tomorrow AM. Had not realized that the really bad potholed roads I drive on could have easily broken a belt in the tires. Thanks for the help, it is greatly appreciated.
| Old Man | Aug 10 2012, 09:55 PM Post #9 |
see if you have a nail in a tire |
| ladybug94 | Aug 11 2012, 07:58 PM Post #10 |
Hi all, thank you so much for the help. Tires are in great shape, problem is a wheel bearing. Passenger side axle nut had come loose and we did not know it until yesterday. We tightened it back down but the damage was already done. So we will be doing the front wheel bearings again on Monday. |
| snowfish | Aug 12 2012, 09:01 AM Post #11 |
Be sure to stake the nut when you're done. I bet that step got missed last time. Axle nut will not come loose if it's staked.
| ladybug94 | Aug 15 2012, 10:48 AM Post #12 |
The mechanic asked if we had torqued the nuts down, I am not seeing a torque spec for them. Do you know if there is? Did not get them done yet but will be staking that nut real well. It had been but not well and the little parts that were bent did not hold the nut. Live and learn they say. Thanks for the tip. |
| clarkdw | Aug 15 2012, 11:01 AM Post #13 |
Front axle nut 129lb-ft according to Factory Service Manual. Wheel nuts 44lb-ft. |
![]() Our users say it best: "Zetaboards is the best forum service I have ever used." Learn More · Sign-up Now |
9:50 AM Jul 11
