front wheel bearing procedure
Topic Started: Aug 10 2012, 11:13 PM (630 Views)
Oldhondatechlarry
Is the front wheel bearings pressed in the wheel hubs? How do you remove the old bearings?
ladybug94
Hi, I am new to this forum but have just done two front wheel bearings jobs on mine and will be doing a third on the passenger side on Monday. Yes, they are pressed in. I used a large socket and hammer to pound out the inner one. The outer one stayed on the axle and I use a puller to pull that one off. Hope this helps a little.
