how does this thing work?; is it the right thing?
Topic Started: Aug 11 2012, 09:51 PM (534 Views)
HelterSkelter
#1 Pizza Driver
i got a 4 inch stone cylinder hone from harbor freight today after seeing it was 100 bucks for a berry hone. is that the right size? it looks like it expands and shrinks. also how do i use this thing? i assume you hook it up to a drill and push it in and out of the cylinder?
i figured i'd ask the pros rather than the nubs on youtube.
bansheetaz
yep thats all i do. i usually turn on the parts washer and let the fluid flow while i hone the cylinder with a drill. doesnt usually take much honing.
clarkdw
Squeeze the hone to install and remove it from the cylinder. Don't slide it vertically at any time unless it is turning. Use a variable speed drill and slowly move the hone up and down so the entire cyl surface is honed. The marks on the cylinder wall should form a crosshatch pattern at 30-45 degrees.
Keep the stones lubricated when honing.
georandy
lubricated with???
georandy
Aug 12 2012, 08:30 AM
lubricated with???
I use kerosene. I guess anything oily and thin that will wash the grind dust out of the hones so they dont gall the cylinder.
Edited by Old Man, Aug 12 2012, 09:11 AM.
