Oil Leak - No Oil found on ground; 1qt of oil is burned off every 500 miles
Topic Started: Aug 16 2012, 03:33 PM (3,297 Views)
94GGGGGEOOO
I still had a leak. I knew it wasn't crank or cam seals. I took the oil pan off and scraped off the old gasket. RTV silicon and no more leaks for this guy! :)
gbt4173
I had a similar loss of oil with 94 Geo. Turned out to be the front camshaft seal. If you are doing the timing belt it's an easy fix. you can get this part along with the front crankshaft seal as a kit for less than you think.
94GGGGGEOOO
I've had a new timing belt, water pump, and crank/cam seals laying around for a month now. I'm gonna knock those out when I get some free time. I'm just happy I don't have an oil leak anymore
