1991 metro rear wheel bearings
Topic Started: Aug 17 2012, 01:02 PM (728 Views)
bourmanr
Just wondering how hard it is to change the wheel bearings on a 1991 geo metro, rear passenger side, are they pressed into the hub or not..Thanks..Bob
clarkdw
Our how to section covers it all. If you browse there you will find out how to do almost anything on a Metro.
Rear Wheel Bearings
ChubZilla
It's not to hard. They are pressed in but you can hammer them out with a punch. Just be careful when you do not to gash the side walls of wear they sit inside the hub.
And when you put your new ones in just use a socket that fits pretty evenly around the outside diameter of the new bearings. Just tap them back in once you've greased them up real good. Also don't forget to put the spacer in before reinstalling both bearings.
