| Cutting out; cuts out on free way after an hour or so then i shut it off and restart and goes for another hour or so | |
| Tweet Topic Started: Aug 18 2012, 10:14 PM (608 Views) | |
| ramrod83 | Aug 18 2012, 10:14 PM Post #1 |
Hi again everybody!Just wanted some advise.I have a 92 geo metro auto with the 1.0.I went to Las Vegas And back from Salt Lake city and my car ran good for the first few hundred miles.I was driving 60-65 mph.Then my car started cutting out and the more gas i gave it the worse it got.I pulled over at the closest gas station,put some fuel cleaner and high grade gas thinking it might help.When i got back on the freeway i thought i fixed it but it did it all the way to Vegas and back(I spent a total of $73 round trip by the way).It would run normal for awhile then act up again but when i shut it off and restart it it stops??????I didnt even stop on the way back(except for gas and lunch) i would throw it in nuetral and restart it and back to normal for a while.What could this be?Fuel filter is pretty new.Could this be the fuel pump?Sensor?Why does it run normal when i restart it?HELP PLEASE!
Edited by ramrod83, Aug 18 2012, 10:16 PM.
| ramrod83 | Aug 19 2012, 09:05 AM Post #2 |
Did I post in the wrong area? |
| Old Man | Aug 19 2012, 09:10 AM Post #3 |
posted area is OK. what is wrong is you posted during Saturday night partying and expected an answer before the Sunday morning hangover wore off. Chill, someone will wake up soon..........(I, personally, do not have an answer for you). Edited by Old Man, Aug 19 2012, 09:11 AM.
| ramrod83 | Aug 19 2012, 09:16 AM Post #4 |
Oh that makes perfect sense.Just got back from Vegas Myself. |
| Bad Bent | Aug 19 2012, 02:32 PM Post #5 |
OK, an automatic at say 40.5 mpg over 850 miles is 21 gallons at $3.60/gallon is $73 That's very good. If it isn't a transmission issue it might be a clogged injector. http://geometroforum.com/topic/2184553/1/ http://geometroforum.com/topic/3880200/1/?x=40 http://geometroforum.com/single/?p=553891&t=4528216 Catalytic converter test: http://geometroforum.com/single/?p=558947&t=4464045 Run/No Run Mystery - oil pressure relief valve But I wonder if it isn't the gas cap or the gas tank as in you should hear pressure releasing when you unscrew the cap. If not you may be looking at a clogged line.
| ramrod83 | Aug 21 2012, 01:21 AM Post #6 |
Thanks for replying.I changed the fuel pump and filter and cleaned the tank out and so far its running very good.I thing ive fixed it. |
9:35 AM Jul 11
