cold start help
Topic Started: Aug 18 2012, 10:50 PM (442 Views)
chadvmurray
what controls a higher idle for cold starts? i think i have a bad sensor or someting for years when i would start my car on a cold morning it would idle high for a min or two until it warmed up a little bit then it would idle down on its own. just the last week it has not been doing this i don't know if its a temp sensor somewhere that is bad or what? :hmm
The ecm controls the idle speed from input sensors such as the temp sensor. Is your check engine light on?
chadvmurray
NO CHECK ENGINE LIGHT I WILL TRY CHANGING THE WATER TEMP SENSOR
It's more likely the Idle Speed Control Motor.
