| Is there one cylinder that burns valves more often?; Have seen two cars with bad cylinder 3. | |
| Tweet Topic Started: Aug 21 2012, 06:21 PM (1,136 Views) | |
| starscream5000 | Aug 22 2012, 09:56 PM Post #16 |
Thanks, you beat me to it. ![]() I must be pretty lucky with my 2 Metros then because in the combined 390,000 miles that these engine have been ran, not once has either of them had a head gasket failure. I must have gotten a good casting on my exhaust manifolds.
| aryaan | Aug 22 2012, 10:04 PM Post #17 |
no no iam not...i even new in this field and learning...this story told me my machanic where i get replace my engine head can somebody confirm me this theory true or not with pictures iam so confused |
| 1DCGUY | Aug 22 2012, 10:18 PM Post #18 |
Don't be a "Richard"
Let me be the first to say, stop asking "that" mechanic about your engine. He is obviously not schooled in the inner working of these motors. Keep asking questions here, and you will get the thruth you seek. You may even get lucky enough to find someone near you to come and help you out, if you have a problem. |
| starscream5000 | Aug 22 2012, 10:26 PM Post #19 |
There is nothing wrong with tthe design of the exhaust manifold on these cars. These motors also do not have a reputation for blowing head gaskets unless the owner has seriously neglected the routine maintenance. The most common issue this motor is known for is burning exhaust valves. And again, this can be prevented with routine maintenance and using high grade synthetic motor oil past the engine break-in process. I've also never burned a valve in either of my cars. Not even on the engine that had over 220,000 miles on it when it was dissassembled. Stop believing what your "mechanic" is telling you and start educating yourself on the workings of this tough little car by reading through the forum for a while. |
| aryaan | Aug 22 2012, 10:45 PM Post #20 |
thanks i found this forum very helpfull i learn alot from this forum....and whats exaust valve? |
| Old Man | Aug 22 2012, 10:55 PM Post #21 |
Tell your "mechanic" that he should stick to wrench turning and leave design diagnostics to the REAL design engineers.-----but then, if he is not a friend then tell him he is full of .....
| Woodie | Aug 23 2012, 06:43 AM Post #22 |
The same expert who screwed up your original head gasket installation? That's either complete bullshit or something specific to the Maruti factory, we've never heard of it. |
| aryaan | Aug 23 2012, 07:48 AM Post #23 |
yes its maruti factory fitted car which come with faulty exaust system and its common problem here in our country...in g10 engine cars i saw many people who change gaskit atleast once in six month duration same problem with my car.....any solution? |
| aryaan | Aug 23 2012, 07:52 AM Post #24 |
several time i changed gaskits and repair head surface...now i completely replace my engine head which cost me alots and iam fear thats its screw up again |
9:34 AM Jul 11
