How do i take of the whole wheel assembly from the cv joint (arm) PICTURES PLEASE.
Topic Started: Aug 21 2012, 10:45 PM (847 Views)
WakaFlockaWatts
So i broke a bolt off trying to change my brake pads and now im trying to take my whole wheel assembly off so im not working under my car. But we have never taken one off before so i need step by step direction for help! PICTURES ARE GREATLY APPRECIATED.
PA.metro,fixer,frames,ect
Frame Fixer
sorry don t do pics....but..three. bolts will get you off car.. lower ball joint-remove bolt push down on a arm, release bottom.... then the two strutt bolts ..and remove hub + brake assembly
It can be removed but I would put some good jack stands under the car and secure it well and work on removing the broken bolt with it on the car. What bolt did you break?
Aug 21 2012, 11:27 PM
3 Bolts and 1 nut. The outter shaft nut.
Frame Fixer
Oh forgot axle nut...center of wheel. If can't break loose.remove with hub.. but trans will loose oil when you pull out of the trans
WakaFlockaWatts
One of the bolts that holds down the brake caliper
Her is a Brake upgrade on a MKII hatchback link with pics.
You can remove the half shaft (axle) without loosing transmission oil if you jack the car up on one side. I placed my jack about 4" behind the wheel with 2x4 wood on it to get a lot of height. I'm thinking 35-40 degrees?
metro_neel
ball joint, cv nut, two strut bolts with nuts, AND TIE ROD END.....
