| Using tracker cluster with tach in my metro? | |
| Tweet Topic Started: Aug 28 2012, 07:47 PM (2,034 Views) | |
| Woodie | Sep 21 2012, 04:06 AM Post #16 |
That's about what my Aerio does, and it's geared much taller than a 3.79 Metro. I'm thinking 2600 is what it should be. |
| razr769 | Sep 21 2012, 09:28 AM Post #17 |
Got boost?
*realized I'm running bigger tires* ![]() my 4.10 is more like a 3.79 with the tires and I'm around 2600 at 55mph what size of tires do you have marx? |
| mjspiess | Sep 21 2012, 11:09 AM Post #18 |
And I'm ~2400 rpm with a 3.79 + 155/80/13 which is essentially a 3.52 final drive. |
| marxtoys | Sep 21 2012, 11:21 AM Post #19 |
stuck in a dent
175/70/13 |
| Woodie | Sep 22 2012, 05:20 AM Post #20 |
Those tires are so close to stock you can't tell the difference. I think your rpms should be closer to 2600. |
| Scoobs | Sep 22 2012, 07:08 AM Post #21 |
With my 4.10 on nightmare running 155/80/R12C tires at 55 mph, im cruising at right around 3100-3200 rpm, when i had the 205/40/17's 55 was at 2600 rpm, In 4th gear. |
7:12 PM Jul 10
