| weak or no spark sometimes | |
| Tweet Topic Started: Sep 4 2012, 12:35 PM (615 Views) | |
| aed3 | Sep 4 2012, 12:35 PM Post #1 |
Hi I just joined the forum. I bought the car like this its a 98 metro lsi 1.3 the story is that the timing belt broke and was replaced and it wouldn't run so I bought it, the timing is right, it has fuel, compression is 150 on all 4. But It only has good spark sometimes on the 1,4 coil and a weak spark on 2,3 coil, sometimes it has no spark on either it also has a new 2,3 coil, cam and crank sensor and I have 2 computers for it, I just can't figure out why it only sparks sometimes . Thanks for any input. My name is andrew |
| Woodie | Sep 5 2012, 05:19 AM Post #2 |
I suspect the crank sensor, does it have an oil pan gasket on it? If so, that's your problem, take it off and replace the oil pan with RTV only as a seal. |
| aed3 | Sep 5 2012, 08:39 AM Post #3 |
Ok ill check I don't think it has one but I hope it does cause that would solve a lot. Thanks and ill tell you if it does when I get home and can look at it |
| Bad Bent | Sep 5 2012, 04:28 PM Post #4 |
What Woodie said and if you want to go looking for errant spark you can get some Windex as Jittney suggested and try this: |
| Oddmodman | Oct 18 2013, 02:20 AM Post #5 |
Hey did you ever figure this out? I'm having the same issue. |
| 2000Firefly1.3L | Oct 18 2013, 09:16 AM Post #6 |
try taking apart the plug towers attached to the coil #2 pack. unset the screw at the bootom of the coil, rough it with sandpaper and apply dielectric grease back on. rough all electrical contacts with sandpaper and grease. re-assemble. you can also measure the resistance of the secondary coil. measure from between 4) Measure secondary coil for resistance. Secondary coil resistance (“a” – “b”): 11.1 – 15.0 kat 20C, 68F If resistance is out of specification, replace ignition coil assembly.
2:18 PM Jul 11
