| manual transmission; manual trans. bolt up to a 4 cyl and 3 cyl ? | |
| Tweet Topic Started: Sep 6 2012, 03:57 PM (632 Views) | |
| 48mpg | Sep 6 2012, 03:57 PM Post #1 |
I have a 1998 chev metro with a 3 cyl and manual transmission.....The engine is bad so I have a 1997 metro with a good 4cyl with an automatic transmission..... Will the 4 cyl engine bolt up to my manual transmission and can I just swap the 3 cyl with the 4 cyl and everything work ? |
| idmetro | Sep 6 2012, 08:12 PM Post #2 |
The transmission itself will work on either. The automatic car has a flexplate rather than a flywheel. The 3 cyl clutch is not the strongest unit, I would be reluctant to put a 3 cylinder clutch assembly on a 4 cyl. engine. Better to make a trip to the wrecking yard, acquire a 4 cylinder flywheel purchase a new 4 cylinder clutch and pressure plate then re-use the trans and go. The 3 cylinder trans will be a shorter final ratio than the manual 4 cylinder trans would be so you will be giving up a couple of mpg but it will work and return better mpg than the auto would. I believe the cv axles are diffrent as well. Good Luck! Edited by idmetro, Sep 6 2012, 08:22 PM.
| starscream5000 | Sep 6 2012, 09:10 PM Post #3 |
You can't swap motors without swapping the wiring harness, all sensors, the computer, brackets, and a few other nic-nac things. |
| 48mpg | Sep 7 2012, 04:48 PM Post #4 |
That's what I was afriad of....haha ...Would be an interesting project.....but, I think I'll just rebuild the 3cyl.....thanks guys !!
| Woodie | Sep 8 2012, 05:19 AM Post #5 |
Like the engine mounts and shifter linkage.
| mdc689 | Sep 8 2012, 06:27 AM Post #6 |
and the dreaded intermediate shaft for the 4 cylinder. Very hard to find.. at least for me it was. |
3:34 AM Jul 11
