| Safe to use engine cleaner? | |
| Tweet Topic Started: Sep 10 2012, 08:30 AM (646 Views) | |
| heckling7 | Sep 10 2012, 08:30 AM Post #1 |
I was wondering if there is any concern with using engine cleaner/ degreaser on a metro engine to clean it up a bit after 16 years of crud? Any precautions and what brand to use? thanks |
| MR Bill | Sep 10 2012, 08:32 AM Post #2 |
I use simple green, be sure to cover the dizz up or u will get water in it, want start then. |
| Scoobs | Sep 10 2012, 09:02 AM Post #3 |
I keep it cheap, if you go to a local carwash where you can wash it yourself, not the automated one, you can use the "Tire Cleaner" option, i think it actually might be stronger than simple green, its green aswell, and is an ultra concentrated solution. Its usually green, its a chemical made by Simononz i know i spellt it wrong, i just forget what the stuff was actually called, i usta work at a car wash with several self serve bays, and a big automated. Spray on tire cleaner, let it sit for a little, spray on some more, then use the water pressure and it will take off quite a bit of crud. Just watch out when you spray near your Dist, since you might not have a gasket under it and get water in your dist cap
| idmetro | Sep 11 2012, 05:13 AM Post #4 |
Be careful! Once you start cleaning you might find you like the results and will have to perform this function more often than every 16 years... |
7:13 PM Jul 10
