Is it normal to have some oil at the pcv valve?
Topic Started: Sep 14 2012, 11:26 AM (1,424 Views)
vikasintl
I see some oil at pcv valve and y tube connection..is it normal?
I don't see much oil in air cleaner assembly....
what causes oil to show up there?
heckling7
I was wondering this as well. I just got done blasting out my pcv valve as it was stuck
starscream5000
Oil vapor is a common occurrence with internal combustion engines. The oil vapor is usually ingested back into the intake to be re burned inside the combustion chamber. Over time, some oil will condensate inside the tube and pool down at the bottom where the PCV valve is at. An oil catch can can be installed and used to prevent the oil vapors from being reintroduced inside the motor. This should over the engine's life span, make the motor stay a little cleaner inside.
vikasintl
starscream5000
Sep 14 2012, 01:12 PM
Thanks....so its normal to have some oil show up at the joint between Y tube and PCV valve...relieved to know...
further how do we check if PCV valve is good?
starscream5000
If you can blow through it, then it's fine.
starscream5000
Sep 14 2012, 01:35 PM
or hold it up and shake it like you are getting ready to roll a pair of dice and listen for it to rattle.
(no oil taste in your mouth this way) ^o)
JoeBob
Why you Mutt!
If in doubt, just replace it. It's not expensive, and replacing it might save you replacing a blown-out crankshaft seal! (Don't ask how I know this!)
vikasintl
Sep 14 2012, 02:20 PM
starscream5000
Well I bought the new one and when I blow....through it...it works one way but I checked with napa,autozone..both...they don't rattle...and they both were brand new...so, rattling is important?
I have 94 geo metro and not later ones...
gold01ca
there is no rattle in a good 94 Geo PCV., but it will pass air in only one direction.
vikasintl
Thanks gold01ca...everyone says it should rattle...even autozone online site says it should rattle and it did not..so I was confused...do you have 94 metro and the same with you? no rattle but blow air from air cleaner to crankcase correct?
gold01ca
guaranteed no rattle in a good PCV for a 94 Metro, I do own the same car.
vikasintl
Sep 16 2012, 03:10 PM
I was wrong--new technology=no rattle
vikasintl
Ok thanks for clarification guys...btw the old pcv valve had rattle.....does it mean it was bad? air was flowing only one way though..
vikasintl
Sep 16 2012, 03:49 PM
thats what its supposed to do--air flow from the engine towards the air cleaner. no air flow backwards to the engine
gold01ca
:gp yup, air flows only one direction.
New Fram PCV does not rattle, maybe your old one is a different design/supplier.
principle of operation is the same.
