| low rpm bearing sort-off noise.. def not alternator.. any suggestions ? | |
| Tweet Topic Started: Sep 17 2012, 10:15 AM (534 Views) | |
| johnda98 | Sep 17 2012, 10:15 AM Post #1 |
Dear Group darn sure is not the alternator bearing.. but sounds like something is 'dry' .. absolutely no vibration, runs fine not sure how good the camshaft bearings are after 100K new oil seals.. no leaks.. noise is coming from the timing belt left side.. tensioner pulley bearing feels firm- no play any suggestions.. I guess I gotta get a stethoscope to find out what it is.. puzzeling ! |
| Johnny Mullet | Sep 17 2012, 10:56 AM Post #2 |
Got any way to post a video with the noise? |
| idmetro | Sep 17 2012, 11:12 AM Post #3 |
Time to get that mechanics stethoscope (or use a large screwdriver as the poor man's version) and see if you can pinpoint the noise. Good Luck! |
| Woodie | Sep 18 2012, 04:45 AM Post #4 |
Could be a loose crankshaft sprocket, that sounds like a rod bearing knock. Take the belts off of it to quickly eliminate the alternator + water pump as possibilities. You can run it for 30 seconds at a time that way. |
7:13 PM Jul 10
