Sep 20 2012, 04:14 AM
Post #16
- 13,848
- Group:
- Tech Certified
- Member
- #471
- Feb 13, 2009
- Location
- College Park, MD
- Year/Make/Model
- 1991 Pontiac Firefly Turbo 2010 Kizashi GTS
It's not RPM and it's not TPS position, it's a rather complicated combination of things basically coming down to a calculated load value. The computer figures out how much power you're wanting at that particular time, if it's possible to deliver that much power in a higher gear with a wider throttle opening, then it lights the light, because lower RPM with wider throttle opening is always more efficient.
