| Coolent in exhaust | |
| Tweet Topic Started: Sep 21 2012, 06:16 PM (521 Views) | |
| truckrat | Sep 21 2012, 06:16 PM Post #1 |
On a 1994 3 cylinder Geo Metro engine, I am getting coolent in the exhaust. I figure it has to be either the head gasket or intake manifold. It was easy to disconect and plug all coolent lines to the intake manifold and the problem seems to have stopped. Has anyone heard of this problem before? Next step is to take the manifold off and replace the gasket but I don't think any coolent flows from the head directly into the manifold. It only flows via hoses. Thanks in advance for any ideas about this problem. |
| Deleted User | Sep 21 2012, 09:21 PM Post #2 |
It could be said that the head gasket has failed. However, the most likely explanation of your "blown" head gasket is that the aluminum of the head and/or block has corroded, allowing engine coolant to enter the combustion chamber. Replacing the head gasket without addressing the condition of the mating surfaces may not be a long term solution. |
| Old Man | Sep 21 2012, 10:45 PM Post #3 |
have you thought about pressurizing the system with an outside pump hooked up where the radiator cap goes? then you could pull plugs and see if there is water in the cylinders, check all gaskets, O rings, freeze plugs etc -------- |
| truckrat | Sep 22 2012, 12:34 PM Post #4 |
At the moment, I don't have the equipment to presurize the system. I also wanted to hook up a compressor to each cylinder (one at a time) to see if bubbles form in the radiator. Thanks to all who looked at this problem. |
| Old Man | Sep 22 2012, 02:37 PM Post #5 |
take a llook at this thread. might want to PM the guy and see where he got the equipment. |
7:12 PM Jul 10
