ECM compatibility; no spark
Topic Started: Sep 23 2012, 09:59 AM (638 Views)
wolfe24
I have a 94 metro l.0 at and a 92 metro 1.0 at. The 94 just quit while going down the road, I found that there is no spark, I replaced distributer, coil, wires from the 92 that does work but still no spark. Is the ECM from the 92 compatible with the 94 just to see if I need a new ECM?
Check your fuses.
wolfe24
Thanks I have checked all fuses relays fusible links etc. I am going outside now to check and make sure the camshaft is intact and engine is grounded properly
wolfe24
In case anyone is interested, the reason there was no spark is that part of the camshaft stopped getting oil and it froze which stripped the timing belt. So I guess I have more to do than I thought lol
clarkdw
Oops, that sucks. :( Good luck with the fix.-
91 ragtop
If it got low enough to stop the cam you better start looking for a whole different engine.
Ken.....
