| Car sputters after it reaches 35 mph | |
| Tweet Topic Started: Sep 23 2012, 02:28 PM (1,331 Views) | |
| vikasintl | Sep 23 2012, 02:28 PM Post #1 |
94 metro manual it sputters after it reaches speeds past 35mph This is not our car...someone else has this problem? my first thought is fuel filter ...but not sure.. so give me ideas why it does that? Oh the guy said it started this problem after replacing motor earlier it was ok...what could be wrong in that new motor or something wrong in installation? Edited by vikasintl, Sep 23 2012, 03:06 PM.
| Scoobs | Sep 23 2012, 02:42 PM Post #2 |
Id check fuel pressure. |
| g10killz | Sep 23 2012, 03:10 PM Post #3 |
stan
throttle switch? |
| wanderling | Sep 23 2012, 03:18 PM Post #4 |
When I had this problem, it was the O2 sensor. Do you know how to check the diagnostic code using the fuses down by the clutch? Edited by wanderling, Sep 23 2012, 03:18 PM.
| Shinrin | Sep 23 2012, 09:59 PM Post #5 |
Only happened when he replaced the motor...Yeah, that narrows it down. Could be a ton of things, my money is on a ground wire left loose!
| vikasintl | Sep 24 2012, 12:05 AM Post #6 |
Wow ...I will check ground wire...I can't imagine ground wire will create problem only after 35 mph |
7:12 PM Jul 10
