How much to torque the torque converter bolts
Topic Started: Sep 26 2012, 08:05 AM (738 Views)
paul11211
Does anybody know how much to torque the torque converter bolts? Thanks.
paul11211
you dont list what year/etc your geo is. I just checked my 91 service manual for a 91 automatic flex plate the torque for the flex plate is described as follows:
Drive rear plate bolts ( 10mm)
*to install drive plate and rear drive plate to crankshaft 40.5 - 45.0 ft. lbs.
Drive plate bolts (8mm)
*to install drive plate to torque converter
13.0 - 14.0 ft. lbs.
paul11211
Thanks, My geo is a 1991 automatic, those numbers should work!
