engine rebuild specifications; crankshaft specifications
Topic Started: Sep 26 2012, 07:57 PM (647 Views)
wolfe24
I have a 92 geo metro 1.0 AT that I am in the process of rebuilding. I have just measured the cylinder bore and the crankshaft and while I can find info on the bore I have not been able to find specifications on the crankshaft. I need to know if it is standard or if it has been turned. If anyone has the specifications I would appreciate the help
starscream5000
Rod crank pins should be around 1.6529" - 1.6535"
Main crank pins should be around 1.7712" - 1.7714"
wolfe24
That's perfect Thank you very much!!
