How to clean trottle body?
Topic Started: Sep 28 2012, 10:46 AM (744 Views)
paul11211
Is there A good tread on here that tells you how to throughly cleaned the the throttle bodys? thanks.
paul11211
Im wondering my check engine light does not come on at all! Im thinking it is probally just the bulb? Well can I replace that, or do I have to replace the whole cluster? Thanks
geogonfa
the check engine should come on when you turn the key on, but not starting the engine...bulb is easy to change, twists into the back of the cluster. it would be easier to give more specific answers if I knew what year Metro...
starscream5000
I just disassembled mine to the point that all was left was the butterfly plate and spring for it. I then cleaned it with carb cleaner and Q-tips.
The put it all back together with new gaskets.
paul11211
I have a 1991 geo metro, and when I turn the key on the check engine light does not come on, like it should?
starscream5000
geogonfa
Sep 28 2012, 03:29 PM
Your answer about the bulb is here.
Star, you missed a spot! :news :-/ :whistle :lol Now That's Clean! :cheers
