Quick Hatch Release Questions
Topic Started: Sep 28 2012, 08:12 PM (894 Views)
94RHDRollerskate
Forum Stud Muffin
Okay, I stopped by my local U-Pull-It yard today, and they just got in a 95 H/B. As luck would have it, it has a hatch release cable.
Questions:
1 - Will a cable assy from a 95 H/B, work on my 94 H/B?
2 - What all do I need to grab? Is it all what is connected together (release handle, cable and bottom striker) or do I need also the upper latch that is in the hatch door too to make it work on mine?
(Tucson members... I call dibs!)
dover
I've got the release for my 93 from an 89, someone else will have to chime in to let you know what kind of compatibilities you have.
You'd need the cable, the lever and the latch (it has an extra arm for unlatching. There's a place to attach it on the floor next to the normal driver's seat. You'll need to do some trickery to have it anywhere else.
Mythstae
I don't know about the years compatibility, but make sure you grab the little white plastic things that the screws for the handle screw into. Once you pull the rug up, you'll see what I mean.
Also, remove them CAREFULLY! I sliced the hell out of my hand once on the skinny metal things the plastic bits on the carpet go over.
take everything you can get loose. probably wont cost any more and extra parts is much better than short a weird part.
94RHDRollerskate
Forum Stud Muffin
Unless someone else chimes in and says not to worry about the hatch latch, I will grab it too, in case it is different from the one on my car and needed to make the release work. Was quote $9, for a sought-after part I've seen on eBay for $75. :thumb
94RHDRollerskate
Forum Stud Muffin
Mythstae
Sep 28 2012, 08:24 PM
Good call on the plastic screw inserts... I planned on getting the screws too, but would have left the inserts.
94RHDRollerskate
Forum Stud Muffin
Bump to the top... still need an answer.
It will not fit. But you could grab it and sell it on here, typical price is around 40, with shipping. You would need the hatch release from an 89-1994.
94RHDRollerskate
Forum Stud Muffin
Sep 29 2012, 07:47 PM
Just my luck... thanks Scoobs.
What about the hatch latch? Is it needed as well to make the whole thing work?
Edited by 94RHDRollerskate, Sep 29 2012, 08:21 PM.
94RHDRollerskate
Sep 29 2012, 08:20 PM
It wont bolt on.
judebert
Supplicant
Will that latch release from a HB work in a sedan?
94RHDRollerskate
Forum Stud Muffin
judebert
Sep 29 2012, 08:50 PM
From what has been said on here, the H/B unit is too short to run in a sedan.
Mythstae
Sedans have their own trunk release set-up. I had one, with latching gas door, but I sold it at Geopalooza...
94RHDRollerskate
The reason people say you need the latch is for the MK5 cars (98-01). The handle and the cable are the same for MK4 and MK5, but in 98 they went to a two stage release mechanism in the latch that defeats the inside release. Therefor, if you're picking up a GEN3 (MKs4 and 5) (95-01) inside release it's smart to get the latch. If it's for your own car and you have a MK4, it's not needed.
In your particular case, you have a MK3, and you don't need it either. All GEN2 (MKs2 and 3) hatchbacks use the same handle and cable and the latch is remote ready. EDIT: I guess not, see below.
Edited by Woodie, Oct 1 2012, 04:10 AM.
dover
Sep 30 2012, 06:29 AM
Not all. I had to get the latch. the body is ready to accept the cable but my original latch was plain.
