Transmission swap; Coolant leak after install
Topic Started: Sep 30 2012, 10:26 PM (362 Views)
Izzy
I recently swapped out transmission on my 96 geo the black steel pipe that goes to the radiator and looks like to the back of water pump is leaking coolant. what did i do wrong and how do i fix it?
There is an o-ring on the end of that black tube behind the water pump. You bumped the tube and upset the seal. Get a new seal from the GM dealer and install it with a little smear of vaseline. One bolt for the coolant tube attaches to the transmission, and one to the back of the engine.
