97 metro transmission problem; wont shift or engage into gears
Topic Started: Oct 6 2012, 12:21 AM (526 Views)
john22baxter
hello i have a 1997 geo metro 3 cylinder manual trasmission vehical i have just started to have problems with trying to upshift into 5th gear and trying to downshift into 2nd and 1st gear when i go to press the clutch and push the stick into the gear it wont go in its like its stuck or jammed and i end up getting stuck on the road with traffic behind me.... is my transmission going out or somthing or somthing with the shift fork please help
There can be several things happening. For the 5th problem. Its a common problem for the phillips head screws that hold the bearing retainer plate to rattle loose. It lets the shafts move around instead of the sliders moving. The shaft moves. Down shifting is hard on syncros. Its common for the PO to abuse a Metro trans then sell it rather than fixing it. Try double clutching to see if it works any better for the down shifting. Sometimes the screw work loose and fall into the oil. Try draining the oil and see what shows up in it. Also check the linkage going from the shifter to the trans. If the bushings are bad or worn you might have problems with the 5th.
PA.metro,fixer,frames,ect
Frame Fixer
Also could be your clutch is going bad or miss a justed
