transmission side speedometer gear
Topic Started: Oct 9 2012, 08:02 AM (630 Views)
opieed1
I am trying to put a standard transmission on my car. I have heard through this web site that you can fill up the transmission oil though the speedometer cable hole. When I tried to remove that 10 mm or 12 mm bolt it broke What next. is there any help out there?
I'd say leave it and just use the normal fill plug. ^o)
Extracting the broken bolt, with the engine/transmission in the car, is not impossible. :hmm But it's going to be a real wrestle. :gamerz It will need heat, possibly a welded nut on the broken stud, drilling, tapping, or all of the above, to get the piece out. :banghead Then there's no guarantee that the speedometer drive will come out easily. :die It's been in there for 20+ years. :smackface
Welcome to the party! :cheers
