| reverse switch connection on 5 spd?; reverse switch wiring | |
| Tweet Topic Started: Oct 12 2012, 03:09 PM (487 Views) | |
| rjsdotorg | Oct 12 2012, 03:09 PM Post #1 |
R E Member
I'd like to keep the '94 base auto engine wiring harness (having a hard time finding a 94 manual with A/C loom) and "simply" wire in the reverse switch plug to the proper pins/wires. I have a donor plug from a non-A/C car with a foot of wire pigtail. The FSM is a little unclear to me as to where to make the connection; has anyone done this, or know the pin(s)? How about the page(s) in the FSM I should be looking at? There are quite a few, unlike the old Chilton style with one big diagram... Thanx |
| clarkdw | Oct 12 2012, 04:01 PM Post #2 |
FSM 8A-112-0 |
| kingthursday | Oct 12 2012, 04:13 PM Post #3 |
Yes I would like to k.ow this as well |
| rjsdotorg | Oct 12 2012, 05:01 PM Post #4 |
R E Member
OK - it looks like I should be able to connect it to pins 1 and 7 of the Park/Neutral connector. I'll post some FSM pics later in the How-to thread. The other I'm looking into is the Vehicle Speed Sensor; the manual seems to not show anything related to manual trans - it seems that just automatics have 2 sensors (speedo and trans mount) and the manual simply uses the speedo one so there's nothing to do in a swap? |
3:33 AM Jul 11
