| Transmission problems; shiftsproblems shifts late/ ticks | |
| Tweet Topic Started: Oct 15 2012, 09:35 AM (509 Views) | |
| Camaroadam73 | Oct 15 2012, 09:35 AM Post #1 |
Hey I've got a 1995 geo metro LSI 4cyl 3 speed auto 4door and I'm pretty sure the trans is starting to let go. When it does I don't want to keep it, so I'm looking for options to swap to a manual 5spd or automatic with overdrive. I plan to keep the car it's otherwise perfect condition 85k no rust solid runner. I'm in pa right now and moving back to nc next year and I don't think the 3speed trans is up for that I'm a mechanic by trade so tools and parts aren't a problem. what other options are there for this car? Edited by Camaroadam73, Oct 15 2012, 09:36 AM.
| clarkdw | Oct 15 2012, 10:45 AM Post #2 |
The 5spd manual swap should be pretty straightforward for a mechanic. There is, unfortunately, no auto od trans that will swap in. Look for a 4cyl 5spd car to get the parts from. Lower numerical gearing, proper axles, mounts and ECM. If you can find a rusty donor car for cheap it will give you everything you need. |
| Camaroadam73 | Oct 15 2012, 12:15 PM Post #3 |
That's what i was thinking. What years should i look for? After the winters over the cars going to need CV axles, and i haven't got around to checking the motor mounts yet. I can pickup a new ECM for pretty cheap, under 100$ through our parts supplier. Edited by Camaroadam73, Oct 15 2012, 12:20 PM.
| Camaroadam73 | Oct 15 2012, 12:51 PM Post #4 |
Just got off the phone with a junkyard that has the transmission pulled, 250$ and they said they would let me come pull the rest of the parts i need for 100$. I'm looking at under 500$ to swap to a manual and kill a whole nest of birds with one stone. Thanks for the info |
3:33 AM Jul 11
