| Something is stuck; not shifting, stuck in neutral | |
| Tweet Topic Started: Oct 18 2012, 05:26 PM (484 Views) | |
| kinnygee | Oct 18 2012, 05:26 PM Post #1 |
I have a 92 metro, I was driving and when downshifting it somehow got "stuck" in neutral. How serious might this problem be? Where do I start to figure out what is wrong? |
| evmetro | Oct 18 2012, 06:41 PM Post #2 |
Might have twisted and jambed a friction plate spring... |
| Potter | Oct 18 2012, 08:01 PM Post #3 |
Col. Potter
might be stuck between gears... does it do it when the car is off? |
| evmetro | Oct 18 2012, 08:58 PM Post #4 |
Potter has the right idea. See if it shifts with the motor off and parked. If it does, pull the tranny and replace the clutch. If it does not, pull the tranny and repair or replace it. (Check the linkage and cable before you go too deep) |
| Murf 59 | Oct 19 2012, 01:16 AM Post #5 |
Also to make sure to check the bushings in the shift assy, when you do these tests. Check the mounts too. A tired mount could mean the trans is not where it should be in relation to the linkage. Let us know what you find. |
3:33 AM Jul 11
