Anyone had a manual trans case to crack?
Topic Started: Oct 24 2012, 01:17 PM (1,571 Views)
93Cobra2771
That's looking like the route I'm going to go with as well.
starscream5000
Oct 25 2012, 01:06 PM
Member mjspeiss has had problems in the past with reman CV axles having an improperly sized input diameter, causing the transmission to leak there. Installing a brand new, non-reman CV axle fixed his leaking issue.
thats what I would try as the next step.....would be cheaper and easier if that would fix the leak.
Jittney
Or rebuild the original ones that did not leak.
Scoobs has a thread on it.
My son rebuilt his.....and it didn't take long.
starscream5000
Jittney
Oct 25 2012, 01:45 PM
:gp
heres the stuff to rebuild the old ones:
http://www.ebay.com/itm/320475799350?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_1631wt_1037OOPS THESE ARE NOT FOR YOUR '96
heres a "How to":
http://geometroforum.com/topic/4691320/1/
Edited by Old Man, Oct 25 2012, 02:57 PM.
93Cobra2771
Wish I still had the old ones, but they are long gone.
Took it back to the shop as its obvious it's coming from the seals. I guarantee I won't be paying any more money, that's a fact. If they had put a mic on those axle journals like I asked in the first place they wouldnt be redoing them.
At least the tranny isnt trashed! thats a big WHEW!!! Still, dealing with a mechanic/shop in that circumstance is not fun.
93Cobra2771
Shop guy was actually in a chipper mood this morning when I dropped the car off. He has a plan of attack on the axles. He's going to Mic them, check it all out, and most likely call a custom seal shop and have a set of seals made. I'm all for it, as it's pouring oil as it sits right now.
I also discussed my finding on undersized axle journals and such, and he agreed it is a good possibility. He is positive it's the right seals, and he is positive they were put in correctly.
In the mean time, noticed the passenger side boot on the axle was torn at the wheel side. I told him to reboot or put a new axle in it, I didn't care. Be crazy not to do it while it's all apart.
Will keep updating as I learn more. Custom seals will take a couple of days, but I have another vehicle to drive so no big deal.
93Cobra2771
Update: looks like the axles were the culprit. Mic put on them and passenger side was egg shaped with a runout of 2.5 mm. They've had it for four days, driving and cycling and looking for leaks. They have assured me it's dry as a bone.
So, I'm out for two brand new (not remanufactured) axles. I'll be taking the reman axles back and should hopefully get a refund on them. It's been a while so not sure if it will happen or not but we shall see.
