| Prime an Engine?; engine sitting without starting | |
| Tweet Topic Started: Oct 27 2012, 04:33 PM (619 Views) | |
| TheAstronomer | Oct 27 2012, 04:33 PM Post #1 |
I have a 93 Metro LSI that has been sitting without starting for about 3 years. It ran fine the last time I drove it but it was simply too small for my family. I would like to get it running again but was advised that it should be primed with oil before I start it. Is this true? If so, is there any way that I can do this without taking it to a mechanic? Thanks! |
| Turbo Dan-O | Oct 27 2012, 04:52 PM Post #2 |
Not really anyway to prime these engines without turning the engine over. If it was me, I would pull the valve cover off, pour oil all over the cam/lifters, pull the coil wire and turn the engine over with the starter for about ten seconds. Then fire her up. It will be fine.
Edited by Turbo Dan-O, Oct 28 2012, 08:53 AM.
| starscream5000 | Oct 27 2012, 05:08 PM Post #3 |
Drain all the old oil out first, then pull the valve cover off and fill it back up by drenching the head in oil. |
| 2000Firefly1.3L | Oct 27 2012, 06:58 PM Post #4 |
may want to crank with the fuel pump relay or ignition coil fuse removed. |
| metro-mike | Oct 28 2012, 05:28 PM Post #5 |
Remove all 3 spark plugs and turn the motor over using the starter. You will be shocked at how fast it will spin over. After the oil pressure is good, turn over the motor with the starter a little longer, and it will circulate all the oil. Also when you have the spark plugs out, squirt some oil into the spark plug hole too lubricate the piston's and rings. Edited by metro-mike, Oct 28 2012, 05:41 PM.
| TheAstronomer | Nov 1 2012, 10:46 AM Post #6 |
Thanks for the help on this... I'll be working on it soon. (hopefully this weekend if my back issue irons itself out) How do I know which oil to select? The manual for the car was stolen years ago (along with the car but the car was found) lol! |
| Coche Blanco | Nov 1 2012, 11:07 AM Post #7 |
5w30 or 0w30, whichever is cheaper. |
| clarkdw | Nov 1 2012, 12:45 PM Post #8 |
3:19 AM Jul 11
