| 4 cyl spark plugs in place of 3 cyl; will this work? | |
| Tweet Topic Started: Oct 30 2012, 07:52 PM (700 Views) | |
| Hugothegrunt | Oct 30 2012, 07:52 PM Post #1 |
Uncle Sam's Metro Club
I need spark plug wires for my 3/5 in a bad way, and no place locally has them, but they do have spark plug wires for a 4 cyl. Will this work???? |
| cwatkin | Oct 30 2012, 08:13 PM Post #2 |
This should work just fine. You will have a leftover plug wire and may pay a little more for this but it is no big deal. Odds are the leftover will be the longest of the 4. Use the other three and you should be fine. There is a 4th one that goes from the coil to the dist so the 3 cly kit will have 4 wires and the 4 cyl kit will have 5 wires. Take each plug wire off your car one at a time and compare the length with one of the new wires and replace with the new one of most comparable length. Conor |
| clarkdw | Oct 30 2012, 08:25 PM Post #3 |
Do the 4 cyl wires have the top seal for the plug well in the head? I don't think so. |
| mwebb | Oct 31 2012, 12:34 AM Post #4 |
FOG
because i get them for free i use spark plug wires for a VW AEG or AVH 2.o engine , the is no provision for a well seal and they do not fit on the OEM spark plugs so i alternate between BOSCH FR7LDC+ or NGK BKUR6ET-10 Spark plugs there is no benefit to using either of these plugs over the OEM NGK BP5ES-11 i only use them because the wires do not fit the OEM plugs the absence of the well seal does not appear to create any problems but i use antisieze and torque the plugs to 25nm |
| starscream5000 | Oct 31 2012, 08:20 AM Post #5 |
There are plenty of spark plug kits out there for the 3 cylinder that do not have the seal on the spark plug boot, so go for it
| Hugothegrunt | Oct 31 2012, 09:10 AM Post #6 |
Once again, Thank you Members of GMF for the quick and knowledgable replies.
| Coche Blanco | Oct 31 2012, 09:15 AM Post #7 |
Ive had them on my engine for the past 10,000 miles.
| razr769 | Nov 1 2012, 12:36 AM Post #8 |
Got boost?
I couple times I've ordered plug wires for a 3 cylinder they came with an extra wire anyways |
3:19 AM Jul 11
