| Fast Idle keeps resetting | |
| Tweet Topic Started: Oct 31 2012, 01:18 PM (749 Views) | |
| old yellow | Oct 31 2012, 01:18 PM Post #1 |
Hi everyone, New to forum and metro's . Just bought a 94 3/5. Had a complete rebuild engine.Guy did a great job .. Problem is with idle . Starts goes into high idle after it warms up idle drops to where it should be. 800-850 . When you touch the throttle on either by hand or accelerator peddle, it goes back into fast idle mode . then slowly backs down.checked for leaks . Haven't found any. checked codes no codes showing.Suggestions ? Thanks for any help.
| sheananigans | Oct 31 2012, 08:51 PM Post #2 |
Ive had this issue for a while. Im not really sure what is causing it either, although one thing I intend to do that you should try as well is properly adjusting the TPS. |
| Memphis metro | Oct 31 2012, 09:26 PM Post #3 |
Just a few things to check, recheck the timing with a light, check for vaccum leaks and proper hose routings, check the accelerator for sticking, check the grounds on the back of the intake manifold (very important). |
| old yellow | Nov 1 2012, 09:36 AM Post #4 |
Thanks Shenanigans and Blue rhino for the reply's. I'm only finding two grounds . one from battery to transmission other is a smaller ground wire from firewall to top of valve cover. are there any threads with a picture of where the ground goes on back of manafold ? and size wire?Thanks again. |
| Woodie | Nov 2 2012, 04:41 AM Post #5 |
![]() We should put this picture at the top of every page, with a caption that says: "Don't ask for help until you've removed, wire brushed, and retightened this connection". |
| old yellow | Nov 2 2012, 01:37 PM Post #6 |
Woody, Thanks for the picture very helpful added the ground wire. Still having idling issue. |
3:19 AM Jul 11
